Flapper
When welding PVC ball valves, is it ok for the glue/primer to touch the ball/seal stuff? I think it would be difficult to avoid when gluing ball valves with slip joints.
Today I ran into a bit of a worry. I had a ball valve, one end connected to the water supply, which was on, and the valve was closed. The other end had a male thread to slip adapter, and I was gluing pipe into it. The valve was tilted with the adapter upwards. After applying the primer, I found that primer had pooled at the end with the ball. I wasn't sure what to do. Do I leave it there or flush it out? Could it contaminate the water supply if I open the valve? If I leave it there, then it would probably stay there and have to be flushed anyway, but through more pipe...
After some hesitating, I flushed it out by opening it completely for a few seconds.
That got rid of it but of course it left a stain...
So anyway is it ok for primer to touch the ball? The damn primer gets everywhere!
