Weird toilet water shut off valve - Please help!
Peter David
Georgia
Hi all, glad I found this forum!
I'm a relatively newbie at DIY so I'm hoping you all can help me.
I've been replacing the toilets in my house and two of them have weird shut off valves.
I don't have the foggiest idea how to turn the water off, maybe somebody here does.
The house was built in 1989, if that helps.
There is a rubber cover of some kind, possibly what you're supposed to use to crank the water off, but they only turn less than a quarter-turn either way.
Thanks for any advice!
Peter David
Georgia
They are 1/4 turn valves, but if a 1/4 turn clockwise does not shut the water off, then the valve is broken and you need new ones.
Yeah pretty sure they're frozen with age. What a PITA.
Thanks for the answer though, now I know what I'm up against.
Cacher_Chick
Test, Don't Guess!
1/4 turn valves are quite dependable, but unless it looks fairly new we normally replace the shut-off valve as part of a toilet replacement. With a threaded-on valve like yours, it should be very straightforward.
When shopping for new valves, avoid those which have a plastic stem. The good valves will be all metal.
