weird situation
zlspear
Alabama
My toilet bowl is slowly overflowing with clean water. The water to the toilet is disconected and the tank is empty. We have not run any water in the house for 2 days and it has slowly over flowed a couple of times.
Is anyone familiar with this???
Is that the lowest drain you have -- including shower, tub?
If you turn off the water to the house, does the water continue to flow?
I would get a utility pump to prevent overflow as a short term treatment.
It sounds like a main line back up. If the main line is plugged, then an fixture elsewhere in the home and cause it to flood. I've seen where people using a shower upstairs will cause toilets to overflow if the line is plugged.
It could also be from neighbors if you share a line with them.
