MountainMan2071
Hello, I am new to this forum and having a problem with my well. I will give as much info as I can.
My well was drilled almost 9yrs ago. It is 660' deep and 6" diameter. I was told the water level was about 50' from surface. Pump is a submersible 220V but not sure of the HP. A 20 gallon tank was installed but I have since had to replace it. The current tank is a 30 gallon pressurized, with a diaphram. One line in and one line out. A 20A breaker, supplies power to a contact switch, which is controlled by water pressure. I believe it is a 30/50 switch.
I noticed weak water pressure last night while using a outside water hose. I first suspected a leak elsewhere in the system. I checked but found no leaks. I checked the pressure gauge at the tank and it was on 0 psi. I checked for power at the contact switch. I had power going in to the switch and out to the pump. Since the pressure gauge was on 0 psi, the contact swicth was supplying power to the pump continuously. Even though the pump was running, I had weak water pressure.
If the pressure gauge caused the pump to run continuously but the water had no where to go, since the tank was full, what would this do to the pump? Would it damage the pump and cause it to be weak or eventually not work at all?
It seems to be reasonable that my problem is caused by a restricted or weak pump. Unless I'm missing something?
Am I missing something or is a pump replacement in my near future?
I appreciate any help you can give!
PS: I have the breaker turned off so the pump will not run continuously.
Type of pump?
Submersible____X____
Two wire (no control)________
Three wire (control box)______
Wire Size_________ Wire Length________
or
Jet Pump (above ground)_________
One or two pipes down the well____
Size of Pump?
Motor Horsepower?__________
Pump Model #______________
Date Pump Installed____2002______
Pumping from?
Cistern tank___________
Pond, lake, river________
Water Well___X_________
Depth of well__660'________
Depth to water____50'_____
Pump Setting__________
Pipe Size_________"
Drop Pipe Material
PVC________
Steel_______
Poly________
Well Recovery Rate_______gpm
Well Casing Diameter____6___â€
Rock Well__________ Sand Well__________ Other______________
Date Well Drilled____2002________
Well Casing Material
PVC___X_____ Steel_________ Other_________
Pressure Tank?
Bladder or diaphragm tank (one pipe to tank)__________
Size or model of tank_____30_______
Air charge in top of tank, with pump off and water drained____________PSI
(check with car tire gauge)
or
Plain Hydro Pneumatic tank (two pipes to tank, one in and one out)_________
Size of tank________________
Pressure Switch Setting?
On 30, off 50 ___X_____
On 40, off 60_________
Other_______________
Pump Control Method?
Cycle Stop Valve model #_________
Variable speed control #__________
Pump Start Relay (sprinkler timer, no tank)__________
Manually turned on and off____________
Pump Protection
Cycle Sensor_________
Pumptec_____________
Low pressure cutoff switch (lever on side)__________
Filters or Softeners______________
Before or after pressure tank_______
Type of filter___________________
Bypass available________________
Water Used For?
House Use__x_____ Number of baths__2_____ Number of People________
High Flow Showers_______gpm?
Plus/Or
Irrigation with timers________
Irrigation with hoses________
Heat Pump______gpm?
Problems Experienced
No Water_________________
Water only part time________
Water at all times but weak__X___
Air in water_______________
Pressure surging___________
Water Hammer (noise)______
Too Much pressure_________
Other____________________
Pump makes clicking or buzzing sounds________
No Sounds______________
Pressure gauge reading____0____psi
Other____________________________________
Do you have, and know how to use
an Ampmeter and Voltmeter_____Yes_____________
Describe Problem__________________________
Type of pump?
or
Size of Pump?
Pumping from?
Pipe Size_________"
Drop Pipe Material
PVC________
Steel_______
Poly________
Pressure Tank?
or
Pump Protection
Water Used For?
Plus/Or
Heat Pump______gpm?
