Weak flush
Discussion in 'Toilet Forum discussions' started by coopns, Nov 18, 2012.
  1. coopns
    coopns New Member
    Sep 25, 2006
    Pulled off the toilet, thought it was leaking, wasn't. (2 year old can't quite make it all the way).
    So I put on two wax rings (flange was below floor...add PVC ext. rings...both waxed together). One had a funnel. Felt a good squish when I put it down. We have noticed though the flush is weaker then before I took it off and have the two rings. The previous ring had a funnel but only one ring. Any thought's on what might be happening? Why the weaker flush? Same amount of water...Frustrated...
  2. jadnashua
    If you get things offcenter, the plastic horn in the wax ring can get collapsed partially. Or, if the excess wax intrudes into the drain, that can narrow the drain and mess things up.
  4. hj
    The obvious answer, but maybe not the correct one, is that you did something wrong when you put the toilet into place, but the only way to tell for sure is to remove it and look. I am not a fan of spacer rings, but only because they are not always secured properly, which means they can be the cause of problems in the future.
Similar Threads: Weak flush
Toilet Forum discussions Weak flush not getting to pit May 6, 2016
Toilet Forum discussions Kohler San Raphael weak flush Dec 8, 2014
Toilet Forum discussions Weak Flushing Drake Sep 15, 2014
Toilet Forum discussions Weak flush Sep 8, 2012
Toilet Forum discussions Brand new Toto Drake 2 piece - extremely weak flush, any ideas? Jun 30, 2012
