Ways to support a pipe 2 feet or so off of wall?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jakkwylde, Jul 18, 2009.
  1. jakkwylde
    jakkwylde New Member
    Jul 7, 2009
    Looking for suggestions on ways that I could support a supply pipe that's about 2 feet off of my basement wall (and 4 feet high) going into my pressure tank for movement. I put some split ring clamps with regular threaded rod over the 3/4" pipe and helped but there is still a little bit of movement side to side (although not too bad). Looking for ideas on how I could support this better.
  2. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    Is this poly pipe and if so, what is the length before connecting to the tank?
  4. jakkwylde
    Jul 7, 2009
    cpvc pipe mostly what i'm asking about. it comes out about two and one half feet before running down to the tank about four feet. it had to come out so far because of some shady work by the culligan man :(
  5. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Can you post a pic?
  6. jakkwylde
    Jul 7, 2009
    here you go
  7. Terry
    Aug 17, 2004
    You cut the pipe, and mount it to the wall.
    Or build a framework out to where the pipe is.
  8. hj
    pipe
    reroute the pipe against the wall, or cut it off so it goes downwards to the floor, at the brass fitting, and then over to the tank. Then put supports between the pipe and floor with pipe strap clamps attached to them.
  9. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Pipe Suport
    :eek::eek: I have to agree with the other posts, cut it off and repipe closer the the wall, then add your supports. :eek:
  10. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    I would use something other than CPVC when rerouting, unless that's what's used throughout your house.
    If you really, really don't want to replumb, run a 2x4 from floor to ceiling, well anchored at each end, next to the vertical run of CPVC, and attach the CPVC to the 2x4 with plastic or copper U straps.
Similar Threads: Ways support
Plumbing Forum, Professional & DIY Advice Towel Rail Radiator Installed Sideways Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Slots Cut Into Highways In Groups Of Three, Why Are They Doing This? May 3, 2016
Plumbing Forum, Professional & DIY Advice No Hub - Do you always crank it to 60lbs Apr 2, 2015
Plumbing Forum, Professional & DIY Advice Moen faucet new cartridge hot water always on in all positions Feb 8, 2015
Plumbing Forum, Professional & DIY Advice Do old natrual gas pipes always leak? Oct 1, 2014
