rfransix
Hi,
When I noticed that the floor board was leaking in the basement from around the first floor toilet, I removed the toilet thinking the wax ring broke.
Well, about 5 years back, the floor was raised with new tile. The contractor put a double wax ring in, and skipped the plumber putty step around the base. Anyways, the first ring was clean; the second ring was hard and broken and dirty.
Would you recommend squirting in caulk, or stuffing plumbers putty around the outside of the flange to prevent leaking through the floor boards?
After cleaning everything and reviewing my options, I purchased a larger wax ring (40% more wax). Well, upon inspection, I noticed a hard material on the inside of the flange in the floor (there is a small ledge on the inside and it appears to be hardened plumbers putty, possibly from the original 1960's install). I started gently scraping this away and realized I didn't know what I was doing. Should I be removing this material? Is it plumbers putty? Is it simply a matter of replacing with new plumbers putty?
I still have the problem about raising the flange. Obviously, the double wax ring idea isn't appealling. I've seen a rubber extension that 'sticks' to the bottom of the toilet for 3" or 4" drains. What's the history of this 'unsticking'? If used, have you used it in addition to a wax ring(s)? It not securing could case damage.
Thanks for you advice. Very much appreciated.
