Wax-Free Bowl Gaskets
Discussion in 'Toilet Forum discussions' started by greekguy7, Dec 11, 2011.
  1. greekguy7
    greekguy7 Member
    Jul 1, 2005
    Illinois
    I have a toilet in a rental that the floor is not in the best of shape so the toilet rocks... and there goes the wax ring. The other day, I put a "number 10" wax ring on it, shimmed the toilet and caulked it so we'll see how it goes.
    Until I get a chance to replace the floor, anyone have anyone have experience with either the Fernco or Fluidmaster Wax-Free Bowl Gaskets and if they would help specifically for this issue? Thanks!!
  2. jadnashua
    If the toilet is properly shimmed, a wax ring is normally all you need. Even if you used a waxless seal, you still need to keep the toilet from rocking and they cost more. They have their place, and I've used them. They're especially handy if you want to repaint, as then you don't need to deal with wax cleanup and buying a new one to reset the toilet.
  4. greekguy7
    greekguy7 Member
    Jul 1, 2005
    Illinois
    Thanks for the reply and I agree with you 100%. But if the floor is in fact tired, would this wax free gasket perhaps be a "little more forgiving"?
  5. jadnashua
    If the floor is rotten, it's time to fix it! But, in the interim, a waxless has a better chance of maintaining a seal.
  6. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
  7. TeXan
    TeXan New Member
    Jan 2, 2012
    Surgeon
    Texas
    i recommend the Fernco Waxless. by far the best waxless solution out there. However the horn of the toilet needs to be perfectly clean to allow adhesive to adhese.. Best when used with new toilet but I have installed them after cleaning the toilet thoroughly with gas a couple of times. The adhesive is very strong! There are 3 different sizes so make sure you get the right size.
  8. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The waxless rings work very well, and from reports I seen on this forum, the new saniseal gaskets work well too. However, you have to have a solid floor. Now, if you are looking for a stop-gap that will work for a very short time, a well shimmed toilet on a waxless might get you by, but only for a short time and no guarantees on that. After you repair the floor and the flange is properly located on top of it, then it's your choice on wax, waxless, or saniseal. Installing a toilet on a rotten floor is similar to building a house on swampy ground.
Similar Threads: Wax-Free Bowl
Toilet Forum discussions Best Wax or Wax-Free Toilet Seal Jan 7, 2016
Toilet Forum discussions Fernco Wax-Free Toilet Seal Jan 18, 2013
Toilet Forum discussions Wax-free toilet seal questions Jul 17, 2010
Toilet Forum discussions Which is better ?Wax Toilet Rings vs Wax-free Toilet Rings May 31, 2007
Toilet Forum discussions Fernco Wax-Free Seal VS. plain wax ring VS. wax + black plastic flange? Mar 27, 2007
