Watts Quick Connect / John Guest style fittings... proper installation?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Killer95Stang, Dec 3, 2012.
  1. Killer95Stang
    Killer95Stang Member
    Mar 24, 2012
    Southern CA
    I just need to make the final connections on my Reverse Osmosis system. Kit I purchased included John Guest type quick connect fittings for the plastic tubing (polyethylene). The tubing that was supplied is color coded and seems to be little stiffer (holds it shape better) than the translucent clear tubing that you find at the hardware store. When I've made compression connections in the past, I always used the brass or plastic anti-crush tubing inserts. Do I need to use them or is it a problem if I use the with the quick connect type fittings?
    Thanks..
    [​IMG]
    [​IMG]
  2. hj
    John Guest fittings do not use the ferrule, at least not on the smaller sizes.
  4. Killer95Stang
    Mar 24, 2012
    Southern CA
    Thanks... installed without the inserts and so far no drips....
Similar Threads: Watts Quick
Plumbing Forum, Professional & DIY Advice Watts quick-connect fittings? Feb 13, 2007
Plumbing Forum, Professional & DIY Advice Watts - Quick-Connect Feb 28, 2006
Plumbing Forum, Professional & DIY Advice Requesting opinions on Watts Vortech Softners Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Do it Yourself Installtion Watts Water Softener Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Watts Swing Check Valve Oct 21, 2016
