Watts quick-connect fittings?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Rancher, Feb 13, 2007.
  1. Rancher
    Rancher Guest
    Anybody use these?
    Connect to Multiple Materials!
    Watts Quick-Connect fittings incorporate Stainless Steel Gripping Teeth in the Collets. These corrosion resistant teeth allow the fittings to interconnect with multiple materials without the need for special tools or tube inserts.
    PEX, LDPE, MDPE, & HDPE Tubings
    Copper
    CPVC
    Polybutylene
    [​IMG]
    Rancher
  2. jadnashua
    I looked at them...not that impressed. One of the things I particularly didn't like was the "Made in China" label. Might be fine. The Sharkbite's seem much more robust (but cost more). Now, I didn't actually use one, they could be fine.
  4. Spaceman Spiff
    Spaceman Spiff Architect
    Architect
    Salt Lake City, Utah
    we use them all the time in pilot valve controllers with no problems at 90PSI. Makes troubleshooting easy since you can disconnect and reconnect them. I use them in my house for the RO drinking water hookup. I like 'em.:) Easier to use than ferrule and compression. I admit I've not used them on metal pipe tho...
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    I have used the Jaco brand fittings (made in USA) http://www.jacomfg.com/j_fit.html in industrial applications with excellent success. Nylon and glass-reinforced polypropylene are good for water applications. Stay away from the Celcon (acetal) if there is even a hint of chlorine in the water.
    They make nuts with stainless steel grippers for hard materials and plastic grippers for softer materials. They are rated at up to 220 psi when used with the gripper nuts.
    The large selection of fittings means you don't need a lot of adapters that can cost as much as the fittings.
    When I was buying them they had substantial discounts from list prices for even modest quantities.
  6. bobcat
    bobcat New Member
    Jun 17, 2008
    Can the Watts Quick-Connect be used to interface 1/2 uponor pex (wirsbo) plastic pipe to copper 1/2.
    If not any suggestions?
    Thanks
  7. Terry
    Aug 17, 2004
    The Watts and the Sharkbites will do that.
    Check the video here
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would personally favor the Cash-Acme Sharkbite over the Watts Quick Connect.
  9. hj
    Plastic
    The plastic ones are easier to disassemble than Sharkbites, and the John Guest ones have a positive locking collet on the larger sizes to prevent accidental disconnecting. They are approved for the same locations as Sharkbites, but I, personally, would not use them in concealed locations.
Similar Threads: Watts quick-connect
Plumbing Forum, Professional & DIY Advice Watts - Quick-Connect Feb 28, 2006
Plumbing Forum, Professional & DIY Advice Requesting opinions on Watts Vortech Softners Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Do it Yourself Installtion Watts Water Softener Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Watts Swing Check Valve Oct 21, 2016
Plumbing Forum, Professional & DIY Advice PRV pressure reducing valve Watts X65B Jan 3, 2015
