Watts Adjustable Floor Cleanout
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Shinshi, Jan 25, 2009.
  1. Shinshi
    Shinshi New Member
    Feb 4, 2008
    Alberta
    I am trying to figure out the best way to make a basement floor cleanout to be as unobtrusive as possible. I would like to set it in the concrete and ensure that it will allow for a flush surface after the subfloor is installed. I am considering a Watts adjustable floor cleanout like a CO-200-R.
    http://www.watts.com/pdf/ES-WD-CO-200-R.pdf
    This seems to be the best option, even if not the cheapest. It would allow me to set the body of the unit in the concrete and then adjust the bronze top to be flush with the finished floor.
    Does anyone have any better or cheaper ideas that would accomplish the same thing?
    I do have a question about this type of cleanout from Watts. I have ABS black pipe for the plumbing and I wonder if it is compatible with this cast iron body. Can I use a vertical ABS black pipe and attach it to this cast iron body or would I have to order the optional ABS version of this body?
  2. hj
    co
    You can attach it with a plastic to cast iron transition coupling, (or a No-Hub one if your inspector allows it. not all will accept the No-Hub.)
Similar Threads: Watts Adjustable
Plumbing Forum, Professional & DIY Advice Requesting opinions on Watts Vortech Softners Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Do it Yourself Installtion Watts Water Softener Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Watts Swing Check Valve Oct 21, 2016
Plumbing Forum, Professional & DIY Advice PRV pressure reducing valve Watts X65B Jan 3, 2015
Plumbing Forum, Professional & DIY Advice Watts intelliflow a2c-m1 removal Jun 10, 2014
