Waterproofing drop-in tub deck
Discussion in 'Shower & Bathtub Forum & Blog' started by djd, Mar 17, 2008.
  1. djd
    djd New Member
    Jan 28, 2008
    insurance
    Canada
    Just finishing my tub install, wondering the best way to waterproof the deck for my drop in tub. I would use kerdi but its not available here(small town Alberta). Will be skinned with concrete board, then tiled. Any suggestions?
  2. jadnashua
    Not sure where 'here' is, but there are on-line sources for Kerdi...check out the store on www.johnbridge.com. I've used them for two personal projects, and it worked out well. They'll cut and send you just what you need, quickly. For the tub deck, I think you could also use Ditra, then you'd need either the KerdiBand, or strips of Kerdi to seal the seams to make it waterproof. Kerdi is designed to install over cbu or drywall...Ditra is designed to install over plywood or concrete. The point being that Kerdi should not be installed directly to plywood, and I think you'd want cbu there, whereas the Ditra could go directly over a plywood deck. Depends somewhat on how you layed the deck out.
    If you have a Home Depot near you, or most tile stores, you could use RedGard from www.custombuildingproducts.com. This is a paint-on (brush or roller) waterproofing material that would work in this situation. You need to tape and thinset the joints first, then after that cures, paint on the two coats of the Redgard. Once that dries, you can then tile the area. This would be easier to waterproof the edges of the tub cutout in the deck. It comes in a gallon can (or larger), so you should have plenty for this one project. The HD usually has it, but sometimes it's not where you'd expect it...
Similar Threads: Waterproofing drop-in
Shower & Bathtub Forum & Blog Waterproofing bathtub cement backer board Yesterday at 11:42 PM
Shower & Bathtub Forum & Blog ValueSeal - Noble Company's 16mil budget friendly shower waterproofing membrane Feb 7, 2015
Shower & Bathtub Forum & Blog Tub Surround Waterproofing Nov 17, 2014
Shower & Bathtub Forum & Blog Maximum time after waterproofing application Oct 18, 2014
Shower & Bathtub Forum & Blog How to test if your waterproofing material has frozen Oct 17, 2014
