Waterproof under sink?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mntentman, Aug 4, 2008.
  1. mntentman
    mntentman New Member
    Aug 2, 2008
    This isn't really a plumbing question, I guess, but didn't know where to post.
    Anyway, I have just repaired a leaking drain in the kitchen sink, and the composite wood floor in the cabinet under the sink soaked up a fair amount of water. I was wondering is there is something I can use to treat it so the water would bead instead of soak in. (I had shelf paper in there, but it ran to the side and under it.) Any advice> Thanks.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    In a lot of rental properties that I worked regularly on, I would caulk all the sides and backs at the bottom, and coat the bottom of the cabinet with a clear spar varnish. I preferred to do this, than come back sooner or later to find the particle board cabinet bottom swelled up like a baloon!@
  4. mntentman
    Aug 2, 2008
    Thanks, Jimbo. Clear spar varnish it is.
  5. Cookie
    Cookie .
    Oct 7, 2005
    If the leak is fixed I wonder why you are worried. But, I used Rain-X on the bottom, but, I only used a very small amount. Really, just a dobber on a paper towel. I wouldn't use any of the Nanotechnology products because of the possible contents/ I wouldn't use them indoors.
  6. mntentman
    Aug 2, 2008
    I'm not worried, just think it is a good idea if it leaks again ever.
    What rain-x product are you talking about?
  7. Cookie
    Cookie .
    Oct 7, 2005
    I just used a regular Rain X, I was careful to use only a small amount, I wasn't sure what it would do, like mar the finish of the wood, or be harmful, but, it seems ok to me. It beads up the water if it leaks. The varnish would probably be better, I bet. But, I just had it sitting in the garage and thought I would try it. I also keep a small bucket under the sink, under the plumbing, and this way too, it is convienent for needing a bucket in the kitchen for cleaning; and just incase it leaks, the bucket is there to catch it. Instead of a contact paper or shelf paper, you could lay down a piece of vinyl flooring.
Similar Threads: Waterproof under
Plumbing Forum, Professional & DIY Advice Waterproof enclosure for PEX manifold in attic crawlspace? Nov 17, 2014
Plumbing Forum, Professional & DIY Advice Shower niche - not waterproof because of gap Oct 6, 2012
Plumbing Forum, Professional & DIY Advice Want to install interior perimiter drain in basement (waterproof). supplies??? Jan 17, 2009
Plumbing Forum, Professional & DIY Advice waterproof gate valve Mar 28, 2008
Plumbing Forum, Professional & DIY Advice Danco Plumbers Waterproof Grease vs Danco Plumbers Silicone Grease Oct 11, 2007
