Waterproof a Laundry Room?
Discussion in 'Remodel Forum & Blog' started by Mad Plumber, Sep 7, 2009.
  1. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
    I would like to know how to waterproof a Laundry Room floor that I am going to tile. I am using 1/2 " treated plywood over the existing plywood and then using Durock 1/4" or 1/2" which ever you think is better. I need to know where to put the waterproofing and what to use. I have not located a pan that will fit. The laundry room is on the second floor and I have installed a center drain rough in. It measures 8'9" x 4"6".
    Thank You,
    Stephen Ayers
  2. jimbo
    jimbo Plumber
    1/2" hardibacker over the plywood should be sufficient. However, you said waterproof and cement board of any type is NOT. You would have to have a moisture barrier under it, as is done in a shower. A better choice for a floor would be redgard coating, or something from the schluter family.
  4. jadnashua
    To ensure the water runs to the drain, you need slope. What you need is essentially a large shower pan with a curb to keep it from running out into the hallway. You could effect a low one with a marble threshold, which MIGHT keep it from running out, depending on the flow rate. Keep in mind, you'll need to run the waterproofing up the wall a little, or it will just run underneath the wall plate. Check out www.johnbridge.com for some additional ideas.
    If you have a pan underneath the washer and run the drain line from it, you wouldn't need the slope. This would NOT help (much) if a hose burst, though.
  5. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Don't use treated plywood. It can have enough movement (shrinkage) to crack tile. Use a schluter product as is done in a shower.
Similar Threads: Waterproof Laundry
Remodel Forum & Blog Will waterproofing fix this outdoor stairs problem? Jul 27, 2011
Remodel Forum & Blog Silicone Base Waterproofing Sealant Jun 14, 2011
Remodel Forum & Blog waterproofing before tile Jan 12, 2010
Remodel Forum & Blog window in shower waterproofing Sep 7, 2009
Remodel Forum & Blog Waterproof windowsills Oct 27, 2007
