Watermain Size
Discussion in 'Irrigation / Sprinkler Forum' started by SHibberd, Apr 14, 2007.
  1. SHibberd
    SHibberd New Member
    Apr 14, 2007
    I have never done a sprinkler system before and I am trying to do a design for a sprinkler system and am stuck at the beginning. How do I figure out the watermain size without digging up my front yard?
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    What size is your water meter? Where is it located?
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You have two considerations here. First the size of the meter and then the size of the line out of the meter. Older homes often had a 5/8" meter which is really too small for running much of a sprinkler system. It would also adversely affect the supply in the house if you were irrigating and trying to shower or wash clothes. When I installed my system years ago, I replaced the 5/8" meter with 1" meter and then ran a new 1" copper supply line out of that. The irrigation tees off about 4' after the meter and goes into a backflow preventer. There is a shut off valve at the tee so I can blow all of the water out in the fall. The sprinkler portion of the system goes from the backflow preventer across the yard about 30' to the side of the house where the valve box is located for the sprinklers. That line is 1-1/2" PVC. My home water is unaffected by sprinkler use, but I still normally irrigate in the wee hours of the morning to avoid as much evaporation as possible. I seriously doubt that the existing supply line will be satisfactory for both yard and domestic use.
Similar Threads: Watermain Size
Irrigation / Sprinkler Forum What's best size of Irrigation pipe Aug 24, 2016
Irrigation / Sprinkler Forum Pipe size for hose bibb Jun 19, 2016
Irrigation / Sprinkler Forum One Size May Not Fit All, Irrigation Woes May 30, 2016
Irrigation / Sprinkler Forum General advice: do these pipe sizes seem okay? Dec 26, 2013
Irrigation / Sprinkler Forum HELP ME with this pipe size... May 23, 2011
