Water wouldn't turn off!
Discussion in 'Shower & Bathtub Forum & Blog' started by jmak, Jul 2, 2009.
  1. jmak
    jmak New Member
    Jul 2, 2009
    Hello, I have a Delta single-handle shower/tub faucet- model number: 1343-NPS. Last night, during my shower, I turned the handle to turn the water off and nothing happened. My shower kept on; the handle did nothing. I had to turn the building's water off in order to get the shower to stop. I took the handle off to look for something suspicious, but didn't find anything so I turn the water back on for the building. The handle then worked normally turning the water on and off.
    Since then, there has been a constant drip from the faucet and if I listen close to the wall, it sounds as if the water is still on slightly even though it's turned all the way to the off position.
    Please help? I don't know how to stop the dripping. Thanks in advance!
  2. Cookie
    Cookie .
    Oct 7, 2005
    Not knowing the age of your faucet you need to either replace springs and seats or a cartridge. They do have rebuilding kits for the cartridges but they are hard to find, some supply houses carry them. It would be easier for you just to replace the cartridge.
    But, I am not a plumber.
Similar Threads: Water wouldn't
Shower & Bathtub Forum & Blog Cold, hot water lines to new bathroom Feb 15, 2017
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Faucet wall tubes and wall tube escutcheon is not water tight Feb 9, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
