Water well Pressure tank inside house
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by vwmartinez, Aug 8, 2013.
  1. vwmartinez
    vwmartinez New Member
    Aug 8, 2013
    Pearland Texas
    I am about to have a water well installed. It is a 1-1/2hp submersible that will be 350' deep and located about 50' from the house. It will include a 120 gallon galvanized pressure tank but I am wanting to have the tank installed inside the house. The tank will be located in a closet next to the kitchen and living room, do these tanks make much sound filling with water that would make me regret installing it indoors in a location like this?
  2. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    I would be more concerned with condensation.
    If the system is set up with air release valve there will be a slight hissing but that's about it.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    You also might hear a little air gurgling each time the pump starts. And if you are using the old style air over water tank because you have Sulfur or something stinky in the water, the air volume control might be letting the "stink" in the house.
  5. vwmartinez
    Aug 8, 2013
    Pearland Texas
    Would the tank have much condensation if it was in a air conditioned space? I guess I could have it installed on a water heater over flow catch pan that drains outside.
  6. vwmartinez
    Aug 8, 2013
    Pearland Texas
    I did not think about the air release valve letting sulfur smelling air out inside the house. I will question them about that. Thanks
  7. craigpump
    Apr 12, 2012
    About the condensation, it would depend on the temp of the ground water where you are. Here in Ct the water is about 53 degrees.
    I forgot about the possible surfer smell.
  8. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Ask Valveman but I think I would recommend a Pside-kick.
  9. valveman
    Mar 15, 2006
    Lubbock, Texas
    No. Not unless you use a Sulfur Eliminator or some other way of getting rid of the sulfur smell without using the big air over water tank.
  10. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    Put the tank in the garage, not the house. It will sweat in the summer time. Our GW temp is 67-72* here in SE Texas. Also have you considered locating the tank outside?
  11. vwmartinez
    Aug 8, 2013
    Pearland Texas
    I am going to go ahead and place the pressure tank outside the house but about 40 feet from the well.
Similar Threads: Water Pressure
Pumps and Tanks Well Forum & Blog. Water is life. Which City water pressure booster pump is right for me to increase PSI ? Apr 17, 2017
Pumps and Tanks Well Forum & Blog. Water is life. City Water - Low Pressure and Volume - CSV or PT? Apr 5, 2017
Pumps and Tanks Well Forum & Blog. Water is life. House on a hill with no water pressure Mar 28, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Feb 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Low water pressure on well system Jan 17, 2017
