Water Well Line - Sediment Filter - Expansion Tank - Water Softener - H2O Htr. Order?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chuck b, Apr 6, 2011.
  1. chuck b
    chuck b sea-bee
    Jan 19, 2011
    levering, michigan
    Have gutted a small 650 small up north (Michigan) cabin and am replumbing it all. Just a small sediment filter there originally and water heater which i removed as they were old.
    Galvanized coming in and will go to copper. dielectric union, 6" brass pipe?? What is the best order...water line to sediment filter, where does expansion tank connect and how, then water soft (any good makes suggest for sed filter and softener) then to water heater and out. also is it a good idea to run a hose bib for watering lawn before the filter? Please advise and thanks a lot!
    Probably a silly question but have not noticed any kind of jumper cable for electrical grounding along water well line - not grounded i guess like a city line thru basement cement and water meters. did see a stake near the electric panel. guessing that grounds the elctrical system. thanks for the advice.
  2. jed1154
    jed1154 Member
    Feb 11, 2008
    Texas
    I am not a plumber, but the way mine is set up is that the sediment filter (A vuflow, I think) is installed AFTER the pressure tank. I was specifically instructed to never install anything between the well and tank. So, its filtered there before going into the softener and into the house. I leave my 'outside' water unfiltered.
    My filter catches all sorts of sand.
  4. chuck b
    chuck b sea-bee
    Jan 19, 2011
    levering, michigan
    thanks. have heard that a "t" is often used from the well source, with one side of the "t' going to the exspansion tank and the other toward the sediment filter. does that sound problematic?
Similar Threads: Water Line
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Reverse osmosis and cooper water line Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Basement water lines Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Cold Water Line to Kitchen not Working Jan 9, 2017
Plumbing Forum, Professional & DIY Advice Water supply line to short for new toilet Jan 2, 2017
