Water to detached garage
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Steve S., Oct 4, 2005.
  1. Steve S.
    Steve S. New Member
    Oct 3, 2005
    I want to run water from my house to a detached garage. Both are on slab foundations. I will bury the pipe 36" (for Chicago winters). How do I keep the vertical sections of pipe from freezing where they enter the buildings?Does the ground under the buildings stay above freezing? What's the best way to enter the buildings for the hookup? Thanks!
    Steve S.
  2. hj
    garage
    If the garage is heated the ground will not freeze, otherwise it will be at the same temperature, or slightly above it, as the garage. If the garage is not heated, the pipe will freeze unless you provide a means of draining the water out of it.
  4. Steve S.
    Steve S. New Member
    Oct 3, 2005
    So do I need to come up through the slabs, or is there a way to get around that? I'll be using the water year round.
Similar Threads: Water detached
Plumbing Forum, Professional & DIY Advice Water Supply to Detached Garage/Living Space Apr 15, 2013
Plumbing Forum, Professional & DIY Advice What kind of water line plan is mine Today at 12:19 PM
Plumbing Forum, Professional & DIY Advice Water supply and meter question Today at 7:46 AM
Plumbing Forum, Professional & DIY Advice Pipe Sizes for Older Water Meter Horn Sunday at 7:40 PM
Plumbing Forum, Professional & DIY Advice Hot and Cold PEX Connections to the Water Heater from Below Thursday at 7:14 PM
