Water test w/ lead roof vent flashing (aka roof jack) causes indoor shower
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DavidTu, Jan 30, 2011.
  1. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    We did our DMV water test yesterday and while there were a couple of small leaks in my ABS connections, the biggest problem w/ detecting the leaks is that there is no real connection between the ABS vent and the lead flashing so as we fill the vent pipe (bottom up w/ Jim cap) when we reach the top the water comes splashing down on everything before we can even turn it off... thus making leak detection difficult, not to mention getting us a little soaked.
    Is there any way to avoid this w/ this sort of set up? Did we not make a connection between the ABS and lead roof flashing (aka lead roof jack) that we should have?
  2. hj
    None that i have ever heard of. That is just the way it works, but the leaking should only be at the lowest roof penetration, so the rest of the system should be dry for testing.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I slowly filled from the top down, shutting off the water when it was an inch from the top.
  5. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    OK then we'll work around it, obviously. Unfortunately the lowest penetration also sits atop a lot of the other plumbing... I guess I should mention that some of the floor are open too so that's not helping. :)
Similar Threads: Water test
Plumbing Forum, Professional & DIY Advice How to pressure test new water lines? Nov 14, 2016
Plumbing Forum, Professional & DIY Advice Air pressure testing water lines Nov 10, 2016
Plumbing Forum, Professional & DIY Advice Water Treatment Advice Needed (See test results inside) Jun 17, 2016
Plumbing Forum, Professional & DIY Advice Humidifier, testing water flow Sep 23, 2015
Plumbing Forum, Professional & DIY Advice water pressure test result questons Sep 26, 2014
