Water tank float switch
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Spaceman Spiff, Dec 18, 2005.
  1. Spaceman Spiff
    Spaceman Spiff Architect
    Architect
    Salt Lake City, Utah
    I have a 1500 Gallon freshwater tank underground that my well pumps into. From this tank I will use a second pump and pressure tank to pressurize the house. The float switch will turn on and off the well pump to refill the tank. I'm planning on running PVC conduit from the tank to the house (where the controller for the well pump is) for the float switch.
    My question is how do you usually get the rubber cord from the tank float switch into the conduit? Do you place a box over it to protect it from the earth or just let it get buried and use a water tight cord grip where it enters the conduit.
    Thanks!!!
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Plan on replacing the switch some day. And you should have access to it for testing when you get a system failure and need to troubleshoot it.
    I would run a conduit to the tank and bring it above ground to a box that is designed for outside service. It need not be a large box. Then I would run conduit from that box to the controller. If you come into the box from the bottom, it dosen't have to be sealed perfectly. In fact, it is better to let it drain. It is almost impossible to seal a box perfectly and you will usually end up with condensation, and therefore 100% humidity, in a "sealed" but not really sealed box.
    If forced to do an underground splice, I would use the sealing shrink tubing materials that are used for submersible pumps. They have a sealant inside the tubing. That means you have to dig a hole to repair it; which is not fun if you live where you get 4 ft of frozen ground.
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    It wouldn't be a bad to run this float with low voltage. A simple 24 volt transformer can be used to keep it safe and then conduit is not necessarily needed. I assume you are using a relay of some sort to start the pump. All you need is a relay with a 24 volt coil.
    bob...
  5. Spaceman Spiff
    Architect
    I was planning on 24V, but still using conduit and a box to do the connection at the tank. It will also need to pop above ground to get above the foundation to poke through the rim board to get inside. Definitely need the conduit for physical protection.
  6. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Makes sense to me.
    bob...
Similar Threads: Water tank
Pumps and Tanks Well Forum & Blog. Water is life. Stand Alone Water Tank & Pump: Jan 4, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Rusty (Yellow and Orange) Water coming from water storage Tank Dec 11, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Complete redo of water plant - replace pressure tank with CSV Oct 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. May I leave my lake water pressure tank out over winter? Oct 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Water Tank Replacement Oct 6, 2016
