geoffjgeorge
Hello There, I am having some trouble with my home water system and was hoping I could get some feedback.
I draw my water from a river cistern (about 300 ft from house). Gets pulled to the house by a ½ HP Jacuzzi pump (about 12 yrs old). From the pump it goes right into a brand new 50 gallon pressure tank (I check the pressure every month). From the pressure tank it goes through a peroxide treatment, then through a Culligan Cul Cleer filter (takes out the metals etc, relined about 4 years ago). From there it goes to a Water Softener and then out to the house.
Here are the issues I am having
1.I recently had a Culligan RO System installed and the RO filters clog within 4 months (supposed to last a year). PLUS I have a 9 gallon RO tank that only fills about 1/3 full at any given time. The Culligan guy said it was because there wasn’t enough pressure in the system (I wonder why they didn’t check that before they installed it?)
2.The water coming out of the rest of the house taps is sometimes cloudy depending on the turbidity of the river (I am guessing fine sediment)
3.I had a new pressure switch installed on the pump to take my pressure from 30/50 to 50/70. After installing it, the pressure is 40/60 at best. The plumber says I need to get a new pump now.
Questions
1.What would you recommend to deal with the sediment issue and where in the system would you put it?
2.Does what the plumber is telling me about having to replace the pump sound right and if so, what pump would you recommend.
Thanks you guys for all your help. For a person on my type of water system, this forum is a Godsend!
Questions
