Pitterpat
HandyWOMAN
Anybody know anything about a water softner leak? It's the Sears model referenced above. It leaks between the bypass valve and the valve body on the inlet side of the bypass valve. When the bypass valve is turned off it does not leak but when it is turned on it leaks at the inlet valve side of the bypass valve that is connected to the valve body of the water softner.
Hope you understand what I asked. Thanks, Pat
