Water softner experts....
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Carl Simmo, Aug 23, 2006.
  1. Carl Simmo
    Carl Simmo New Member
    Aug 21, 2006
    Hi- I have a G.E. gxsf39e water softner it's about 2.6 yrs old. It softens the water fine (no problems) \, it just seems to regenerate itself every other day and at 32gals per time:eek: . It's like doing it 15 or so times a month, does this sound normal or possibily a problem???
  2. Rancher
    Rancher Guest
  4. Gary Slusser
    Retired
    It sounds as if it s too small for your needs. The largest softener you can get at a big box store is usually a 1.2 cuft. Larger won't fit in any cabinet model; that's where the resin tank is in the salt tank.
    If you reduce the hardness setting, you will not get consistent soft water, nor remove all the hardness between regenerations.
  5. Carl Simmo
    Aug 21, 2006
    Thanks for replying Gary & Rancher, I do have the manual but it does'nt really referance any troubleshooting for regenerating (but thanks ).
    On G.E. website they say that model is good for a family of 4 (we only have 3), with normal shower usages. The settings goes as high as 110 which is really soft water, and I have ours set at 26. Just a little confused about why it wants to regenerate every 2-3 days, it does'nt sound normal, unless I'm missing something:confused: . I have cleaning everything in there and all filters, fittings and even the old salt in the bottom.
    Could this be normal ??? Awesome forum BTW:D
Similar Threads: Water softner
Plumbing Forum, Professional & DIY Advice Fleck 5600 Water Softner Sep 9, 2016
Plumbing Forum, Professional & DIY Advice New Water Softner Standpipe and Bar Sink Dec 30, 2015
Plumbing Forum, Professional & DIY Advice Estimate for installing water softner loop May 12, 2015
Plumbing Forum, Professional & DIY Advice Is this a drain? (above water softner loop) Oct 21, 2012
Plumbing Forum, Professional & DIY Advice 3/4 Inch Water Supply, 1 Inch Water Softner??? Sep 14, 2012
