Water softener WHES40 & Central Water Filtration System - Questions
Discussion in 'Water Softener Forum, Questions and Answers' started by reggiev6, Dec 14, 2011.
  1. reggiev6
    reggiev6 New Member
    Dec 14, 2011
    California
    Hey guys,
    I just got my water softener and water filtration system installed (about 1month now). everything has been going well and there is a big difference on how the water feels on the skin, very silky/smooth.
    Questions:
    I poured about 3 bags of blue bag salt that's sold at Lowes, but didnt pour any water in there. The company that installed it (recommended by Home Depot) didnt say I had to pour water but now I look online and people say I should. Is this something I should do? Can I do it now even though I have the salt at level 5? What's the point of pouring water in the salt?
    Sorry for the dumb question but I'm really new to it.
    The other thing i've noticed is that my toilets (I have 1 downstairs and 2 upstairs), are getting not a brown ring but more like a little brown stain where the water sits all day. This is happening to only 2 of the toilets, the 3rd one is fully clear. I was curious on what's causing this? Is the products I bought, not working or are they faulty? I'm kinda worried :(
    http://www.ecodynewatertreatment.com/ws/whes40.asp - water softner
    http://www.ecodynewatertreatment.com/cwfs/ - central water filtration system
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    The softener adds water after every regen and I'm guessing it has done a regen by now so there should be water in it. The brown stain is probably iron.
  4. reggiev6
    reggiev6 New Member
    Dec 14, 2011
    California
    thanks for the quick reply!
    is that iron normal? doesnt the water softener and filtration take that out? is that normal for a home with this setup or do i need to get something checked?
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    There are different methods to remove iron depending on the type and quantity of iron. A water test would be a good start. One method is to oxidize it to trap it as rust.
    The iron is probably oxidizing in the bowl as it is exposed to the air.
  6. reggiev6
    reggiev6 New Member
    Dec 14, 2011
    California
    so even with the water softener and water filtration system, this is a normal thing that happens to homes? the company that installed it said they tested the water and set the hardness level of the softener to 12. If this iron thing in the toilet is normal for the home then I wont worry about it too much. i just always thought that water softeners removed these things
    also to add, if the water has iron, should i be worried about the water in the faucet that we drink?
  7. Gary Slusser
    Retired
    A softener or iron filter only takes out the hardness and iron in the water where it goes into the softener or filter.
    If there is rust in the plumbing past the unit, the softened water can remove it depositing it in a toilet etc. OR, if there is any galvanized pipe or nipples, the softened water will rust them and add iron to the water that then is oxidized by air and the rust settles on surfaces.
    I think you are saying you have a ring at the water. If it were iron it wouldn't be just a ring, it would coat the surface under the water.
    Your softener may be pre brined (dry brine), meaning the water to dissolve X lbs of salt is added at the beginning of a regeneration, not at the end. If so there is only an inch or 2 of water in the salt tank between regenerations.
  8. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    There, I fixed it for you.
    I wish that came with an iron clad guarantee that if I got a hint of iron anywhere, I'd get my money back. I have an iron filter that judging by what the backwash looks like, removes a lot of iron. After that, I assume my softener removes some that the iron filter missed. Then after that, I use only RO filtered water to make coffee, yet there is still iron staining in my coffee maker.
    There is no iron fixtures in my plumbing with the exception of the water heater (supposedly lined) but none the less, I don't use water from the heater to make coffee.
  9. Gary Slusser
    Retired
    In context it didn't need fixing.
    Believing what you say, then your iron filter, softener AND RO is not working correctly.
Similar Threads: Water softener
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Sunday at 12:24 PM
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
Water Softener Forum, Questions and Answers Water softener size Feb 9, 2017
Water Softener Forum, Questions and Answers Water Softener & Whole House Filtration Feb 8, 2017
Water Softener Forum, Questions and Answers Is my watersoftener broken? Jan 29, 2017
