Water Softener Start up Question
Discussion in 'Water Softener Forum, Questions and Answers' started by Allex, Jan 20, 2012.
  1. Allex
    Allex New Member
    Jan 20, 2012
    Ann Arbor, MI
    Hello,
    I just installed a "new" (only new for my house) softener and don't know how to start it up. I have included the picture of the control panel, which has a main dial without any names/marks besides a single dot. I don't know where I should turn it in some position to run the cycle or just wait for a day and clock to come around and run on its own. Any information is greatly appreciated. By the way I searched the internet and couldn't find the manual on the unit, maybe someone can point it out.
  2. Teets
    Teets CT pump guy
    Aug 23, 2007
    well tech
    Watertown, Connecticut
    Google Fleck 2510 manual. Use first link, and scroll down to page 15.
  4. ditttohead
    Jan 9, 2012
    Ontario California
  5. Allex
    Allex New Member
    Jan 20, 2012
    Ann Arbor, MI
    Thank you for the helpful information. I have turned the main knob and started the manual cycle. Do you know when will be the next automatic cycle and can it be set up for a certain time of day when I am not going to be home?
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    No we don't know when will be the next automatic cycle because we have no clue how you set the timer up. You need to know the grains hardness to be removed, iron ppm to be removed and the number of people in the house and then go here
    http://www.pentairwatertreatment.com...Fleck+2510.htm
    Read the manual and set the timer. It can be set to regenerate any time you want it to but most folks set it for around 2 am
  7. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    If nothing has been changed from the photo, the next cycle looks to be in 1000 gallons.
    How long that 1k gallons is going to last is going to be based on how your house hold uses the water.
    From the factory the normal time is 2am when the meter has reached 0.
  8. ditttohead
    Jan 9, 2012
    Ontario California
    It is critical to know a few things before the system can be set correctly.
    Raw water hardness
    System size
    How many people in the house
    Does your water have iron or manganese
    Also, on that valve I need to know what size BLFC, the sticker on the valve that the brine line goes into will be blue, black or red. (black is the most common). .25 GPM, .50 gpm, or 1.0 GPM.
  9. Allex
    Allex New Member
    Jan 20, 2012
    Ann Arbor, MI
    I haven't done water hardness test yet. However do you know how Iron effects the settings of a system?
    Thanks again!
  10. ditttohead
    Jan 9, 2012
    Ontario California
    Water softeners can be used for iron removal, although by todays efficiency standards it is not a good idea. The iron levels will be calculated into the hardness settings. 1 ppm or iron = 85 PPM of hardness, or 5 grains. It will also determine wether the system can be regenerated efficiently or if the salt has to be set to a higher level to lessen iron fouling. It will also affect the backwash timing. Municipal Iron free water can be adjusted to a very short backwash with no negative affect. Water supplies with iron require extended backwash rates.
    The information mentioned above will allow me or any other water softener technician to assist you with setting the system correctly. It is critical that a salt regenerating softener be set properly to minimize waste which is good for the environment and our industry as a whole.
Similar Threads: Water Softener
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Yesterday at 12:24 PM
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
Water Softener Forum, Questions and Answers Water softener size Feb 9, 2017
Water Softener Forum, Questions and Answers Water Softener & Whole House Filtration Feb 8, 2017
Water Softener Forum, Questions and Answers Is my watersoftener broken? Jan 29, 2017
