Water Softener ruining my hot water tank????
Discussion in 'Water Softener Forum, Questions and Answers' started by kskier, Apr 30, 2010.
  1. kskier
    kskier Home Handyman
    Sep 4, 2007
    Home Handyman
    Buffalo NY
    I was wondering if anyone has any info that a water softener caused a hot water tank to prematurely fail? I have had to replace my hot tanks (I have 2)3 times in the last 10 years. I am on normal city water. Someone told me, that if I remove the anod rod in my hot water tank, that will solve the problem. Any help??????
  2. Skip Wolverton
    Skip Wolverton In the Trades
    Dec 27, 2009
    Owner of SWS Systems. I work on most water treatme
    Ocala, Fl
    I don not recommend you remove the anode rod. It's there to keep the water from eating the tank and causing a leak.
  4. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    What type of water heater? - gas-oil-electric-indirect-tankless
    Manufactured by whom?
    Reason tank failed?
  5. kskier
    Sep 4, 2007
    Home Handyman
    Buffalo NY
    gas fired,,,,,,,,,,,,,"State" tank started leaking...50 gallon....65,000 BTU.......someone told me that the water softener will cause the anod rod to corrode twice as fast, which will put more rust in bottom of tank, causing bottom of tank to heat up more than rest of tank causing a leak????Is this right??
  6. jadnashua
    First off, State is not held here as one of the better brands. Second, you mis-understand the whole purpose of the (sacrificial) anode rod in a WH. That rod is designed to be attacked IN PREFERENCE to the steel of the tank. In a normal situation, that rod often lasts the life of the heater. Checking and replacing the anode rod periodically if dissolved will potentially extend the life of the steel tank (even if it is glass lined). Sacrificial anodes are used everyday on thing like this, steel-hulled ships, buoys, etc. If they are replaced before they are totally eaten up, the ship, buoy, etc., will last a long time...same with a WH. While there may be a little debris left from the annode, it essentially gets eaten up, and there's nothing left to clutter up the bottom of the WH tank.
Similar Threads: Water Softener
Water Softener Forum, Questions and Answers Water softener discharge question............ Mar 11, 2017
Water Softener Forum, Questions and Answers Extending length of water softener drain Mar 4, 2017
Water Softener Forum, Questions and Answers Water softener and iron filter sanity check, before I purchase Mar 4, 2017
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Feb 19, 2017
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
