Water softener resin is green
Discussion in 'Water Softener Forum, Questions and Answers' started by earlrabbit, Mar 3, 2013.
  1. earlrabbit
    earlrabbit New Member
    Jan 1, 2013
    Salt Lake City
    I've been having problems with my 14 year old Northstar softener. I suspected that the resin might be bad as I've never run anything like "Iron Out" through it. After opening it up I see that most of the resin has an amber color but some has turned green. I don't see anything that looks like iron contamination. Is the resin bad? I've been inside the valve many times so I'm very familiar with it but is it time to bite the bullet and buy a new one?
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Take a few beads and crush them between your thumb and forefinger. If they crush they are bad. Try it with both the amber and green beads. I suspect that either the resin is failing, the resin is channeled or the bed is not being properly back washed
  4. ditttohead
    Jan 9, 2012
    Ontario California
    Can you post a picture? Green might be an indicator of copper fouling. Considering the age and make, it might be a good time to start looking for a replacement system.
  5. earlrabbit
    Jan 1, 2013
    Salt Lake City
    I was able to crush them between my fingers so it sounds like the resin is toast - right?
  6. Gary Slusser
    Retired
    Amber is a color of a resin. Green is usually from copper, so on site copper and pH tests would be in order.
    What is your raw test showing for pH, iron, total hardness etc.? Are you on your own well or 'city' water?
  7. Tom Sawyer
    Nov 29, 2010
    Maine
    Yep it's toast and considering the age of the equipment I highly recommend scrapping it and starting new.
  8. earlrabbit
    Jan 1, 2013
    Salt Lake City
    Not sure on pH, but hardness is 13.85 grains/gal and iron is .03 mill/ltr. It's city water but they source part of their needs from wells.
Similar Threads: Water softener
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Monday at 7:41 AM
Water Softener Forum, Questions and Answers Water softener size Feb 9, 2017
Water Softener Forum, Questions and Answers Water Softener & Whole House Filtration Feb 8, 2017
Water Softener Forum, Questions and Answers Is my watersoftener broken? Jan 29, 2017
Water Softener Forum, Questions and Answers Redoing water plant - Iron treatment and water softener suggestions Jan 27, 2017
