water softener recharge problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jmom, Dec 6, 2006.
  1. Jmom
    Jmom New Member
    Dec 6, 2006
    I have a Kenmore water softener. It's about 6 years old, never had a problem with it until now. It is only supposed to recharge on an as need basis, but we had a power outage recently and ever since our softener is recharing every 2 days. I went through and checked all my settings, and they are correct. It shows it to recharge only when needed, but it's not doing that. What could be wrong?
  2. Gary Slusser
    Retired
    It sounds as if it may have lost the master (non consumer) programming. I think you'll have to call Sears. They may suggest a new circuit board or tell you how to get into the master programming if there is such a feature in their softeners.
  4. Jmom
    Jmom New Member
    Dec 6, 2006
    If I lost the master programming, wouldn't I have lost my whole display? Eveything else works fine. It shows that is has recharged and it lets me know when the salt is low. I haven't lost any of the display, it just recharges every 2 days, even though it is set to recharge on as need basis.
  5. Gary Slusser
    Retired
    the answer is no, you wouldn't lose the whole display if something has changed in the prgraqmming. I.E., a bad tv comes on but you don't get all or any channels. Or, the clock works on your clock radio buit you don't get any stations, so no favorite music OR, it fails to wake you on time. I used to troubleshoot radios for a living...
    The above "non consumer" means that your manual, their web site etc., is not going to mention the master/dealer programming but... I could be wrong and it isn't anything with the programming but we both agree, it ain't working as it used to and it should be. So call them and run the problem past them and let us know what they come up with. Also check for a serious water leak past the softener that may be causing a regeneration every other day (or we could say every two days).
Similar Threads: water softener
Plumbing Forum, Professional & DIY Advice Low Volume Water Softener (8 gal./week) Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Water Softener Recharge Drain Dec 28, 2016
Plumbing Forum, Professional & DIY Advice No drain near water softener Dec 27, 2016
Plumbing Forum, Professional & DIY Advice Do it Yourself Installtion Watts Water Softener Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Drop in water pressure after new softener put in Nov 3, 2016
