Water Softener problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bjp, Aug 27, 2008.
  1. bjp
    bjp New Member
    Aug 27, 2008
    Hi... I have a 6 month old softener, a Professioanl Series by Water Technologies, Inc. Whenever it regenerates, we get lots of air in our pipes. So much that when we turn the shower on, it spits and pops and shudders for 2-3 minutes. In addition, I still have some hard water deposits. Any suggestions? Thanks!
  2. Gary Slusser
    Retired
    The most common cause of that is loose brine line connections allowing it to suck air or the brine pick up tube's air check is not closing and that allows air into the resin tank but... if you are on your own well, the water level in the well could be down to the inlet of the pump or foot valve allowing the pump to suck air.
  4. bjp
    bjp New Member
    Aug 27, 2008
    I'll check it out. Thanks for the help--have a great day!!:)
Similar Threads: Water Softener
Plumbing Forum, Professional & DIY Advice Low Volume Water Softener (8 gal./week) Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Water Softener Recharge Drain Dec 28, 2016
Plumbing Forum, Professional & DIY Advice No drain near water softener Dec 27, 2016
Plumbing Forum, Professional & DIY Advice Do it Yourself Installtion Watts Water Softener Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Drop in water pressure after new softener put in Nov 3, 2016
