Water softener problem, elevated copper in drinking water
Discussion in 'Water Softener Forum, Questions and Answers' started by SMS1944, Aug 11, 2012.
  1. SMS1944
    SMS1944 New Member
    Aug 11, 2012
    NJ
    My wife and I have no understanding how to resolve our problem. We noted blue-green discoloration in our toilets. We tested our well water and there was no significant copper emanating from the well and the first draw from our faucet read 0.62. We thus had corrosion causing leaching from our copper pipes. A water softener company checked our water. The pH was 7.5 at the sink and we were told that we had elevated CO2 in our drinking water. We previously had a water conditioner and neutralizer. We called a national company who added soda ash but we were unable to maintain a stable pH in our sink water. They then tried Carus 4200 orthophosphate. After two months, again there was no copper emanating from the well and the sink first draw showed the same elevated 0.62 copper level. Our pH remains at 7.5. The Carus company (manufacturer of orthophosphate) stated that probably our water was made too soft for the orthophosphate to be effective. I told this information to the national water softener company and their response was to remove all their equipment and return our money. They were unwilling to try to alleviate the problem by increasing slightly the hardness of the water. Well, with no solution, we called a local non -national water treatment company. He did not retest our water, referring to our previous independent lab evaluations. His solution was to maintain our previous 2 cu ft Clack softener with a dome top,add two 10" x 54"filter 5800 SXT-neutralizer with a 80%Corasex-20%Calcite blend, properly ground the well tank to house electrical main, maintain a ph 8.2-8.6. He assures us that this will eliminate the excess copper leaching from our corroded pipes. He is charging $3000 for the 2neutralizers and $1250 additional parts and labor. My specific question is whether this seems like a reasonable corrective action. The price is high but I am willing h spend an extra $4250 if this will finally correct the problem. We have septic too and are concerned that the PH may become too high and cause a problem. We don't know if this system can properly regulate the PH. We are at wits end. Thank you, Stephen
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Yea, other than blending hard water past the softener which is a bit hard to control that's a pretty good solution and should solve the problem. Can't comment on the price, every area is different and I have no idea as to their overhead and such but I can tell you that we would be in that ballpark too.
  4. Gary Slusser
    Retired
    I really question the 80% Corrosex and the 2 AN filters but IMO you should have questioned this before getting the $4250 bill but, now time will tell if it works or not.
    BTW, I think $4250 is way high; you'd swear the guy was a plumber instead of an independent water treatment dealer.
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    It would be curious to know how much CO2 there is and whether controlling it at the pump with a special sleeve would be warranted. It is probably converting to carbonic acid.
    I aerate my water for iron filtration and it seems the CO2 converts to carbonic acid in my RO filter.
  6. Tom Sawyer
    Nov 29, 2010
    Maine
    BTW, I think $4250 is way high; you'd swear the guy was a plumber instead of an independent water treatment dealer.[/QUOTE]
    Yep, but he wasn't was he LOL For the record though, I think it's a bit high also but there may have been mitigating circumstances or maybe the guy was late on his child support LOL
  7. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    It's comments like this that I think your daddy show have named you Richard. LOL
  8. ditttohead
    Jan 9, 2012
    Ontario California
    I am not quite sure what the need for a comment about plumbers was for but it is not unexpected.
    Regarding the system they have designed for you. it should work but it does have a minor flaw. Mixing corosex and calcite in the same tank is a common practice, but maintaining those levels accurately is difficult due to the different absoption rates of the different medias. Another solution may be to do seperate tanks with the calcite and corosex. This would allow you to monitor adjust the levels and bed depths of each. Either way will work fine, as long as you understand the drawbacks of mixing 2 different consumable medias in the same tank with different absorption rates. In all reality, the calcite will have very little function other than as a filler since the corosex is much more easily absorbed into the water. We mix calcite and corosex all the time, and the calcite is used to replace the corosex so as to "weaken" it. I know the terminology is wrong, I am trying to simplify it. Corosex is approximatrly 5x more neutralizing than calcite. If you over correct with corosex, you can remove some of it and replace it with calcite. The opposite is also true, if the calcite is not strong enough, corosex can be added to improve the reactions.
    Corosex is magnesium oxide, (Milk of Magnesia) and if too much is used, a laxitive affect is common.
    It looks like you are on the right track for your problem. Does your well system have an atmospheric storage tank?
  9. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    If I under stand the water correctly, the ph is above 7 and there is blue green showing up.
    Has any one checked to make sure that the electric ground is correct and that there is no electric bleed to the copper lines with in the house?
    Has the water heater temp been turned up from 110 to 130+?
    Just some thoughts out side of the use of soda ash or other media to correct the ph.
  10. Gary Slusser
    Retired
    Neither were the replies by you and your good buddy Tom, "unexpected".
    In my opinion, that is a bunch of Californian type PC speak... If you do it, but do it differently, are you really doing what he is doing? I don't think so and what is your "it should work" based on since you don't do it the same way? And then you ask about an atmospheric storage tank.. with no explanation of why.
  11. Tom Sawyer
    Nov 29, 2010
    Maine
  12. Gary Slusser
    Retired
    I notice he frequently says he's "not quite sure".... maybe that's enough detail for you but I know it isn't for DIYers wanting info on water treatment.
    BTW, 'trying' usually doesn't mean success.
  13. Tom Sawyer
    Nov 29, 2010
    Maine
    This is the only place I see the words I am not quite sure but I believe that it was a rhetorical question as I am more than sure he knows why you posted what you did. Which also BTW, has nothing to do with the OP's problem either. Perhaps if you kept your ignorant prejudices to yourself things would be a lot clearer LOL
  14. ditttohead
    Jan 9, 2012
    Ontario California
    Someone forgot to turn on their sarcasm filter. :)
    My main point was that someone already tried the accepted, common, traditional method that works 95+% of the time. This time, it did not work so we may need to look at a different approach. Adding Corosex is a good idea to try to correct the problem, and the guy who is offering you a solution for a very high price is also taking on the liability of that this solution may not work and he will be responsible for multiple trips to the jobsite to try to correct the situation.
    An atmospheric tank can be used as part of a solution if he has one, if he does not, then why would I go into a 50-100 word explanation that will have no bearing if he does not have one. If we have to explain the reason for every question, these threads will be longer than they already are. A simple yes or no will then lead to a potentially different solution or method. Do I really have to explain why we ask what their hardness is every time we ask? The pH, the water temperature, etc...? Your question about the atmospheric tank had no bearing other than to drag out (troll) unnecessary debate.
    Considering the path this thread has been dragged down (as usual) the OP has probably bailed and is trusting on the knowledge of his local dealer who probably has dealt with this exact issue that is specific to his region. Local dealers have a huge advantage of knowing what treatment methods work for the local water supplies that the online guys simply cant have. We can try to assist with our basic knowledge and understanding of water chemistry and our experience, but many water supplies will not be treated by standard treatment methods. That is why we usually rely on a little overkill, so as to minimize the potential for a water treatment method not working.
  15. Gary Slusser
    Retired
    Your main point... there were like 28 points.
    So I take it that you see no problem with 80% Corrosex and 20% calcite.
    You have no idea of how the new guy will handle a failure of his non standard and WAY HIGH PRICED idea. And so far you haven't said you've used it.
    I didn't count these words now but as usual you are going on'n on'n on while saying nothing to benefit the OP about the use of an atmospheric tank.
    The OP already bought the new local guy's stuff.
    You mean local dealer as in the other local dealer that pulled his failed equipment out already... I guess you know this new guy.
    Your anti DIYer attitude is showing again but tell us, what experience do you have with using an 80% Corrosex and 20% calcite mixture?
    My experience with Corrosex is that too much and you get serious overkill. Other than the laxative affect you previously mentioned, what might happen IYO?
  16. ditttohead
    Jan 9, 2012
    Ontario California
    lol, what experience do I have? You didnt load that question did you? If I answer about my experience, you will claim I am bragging and even so, my experience means nothing to you regardless. Stop trolling and answer the OP in a professional manner. Other than selling, applying, and installing container loads of calcite and corosex medias for residential, commercial, industrial, municipal, waste water etc, my experience with Calcite and Corosex is really minimal.
    Applying corosex is difficult, but it can be done by using simple tables provided by the manufacturer, and with a proper water test, which you have stated on many occassions is a waste of money. Obviously if you think 80% Corosex is always a bad idea, then good for you. I prefer to follow the manufacturers application recommendations, experience, and proper testing methods. That is how licensed professionals usually do it.
  17. Tom Sawyer
    Nov 29, 2010
    Maine
    My god......another anti DIY member? But I thought I was the anti-DIY guy LOL
  18. Gary Slusser
    Retired
    Yes applying Corrosex is difficult, especially in residential applications like the one in this thread.
    Anyone interested in using Corrosex (or the manufacturer's FloMag) check out what Clack Corp says about it.
    http://www.clackcorp.com/downloads/ion_exchange_resin_and_filter_media/corosex_2616.pdf
  19. Tom Sawyer
    Nov 29, 2010
    Maine
    You know what Gary? There are 17 replies in this thread and I don't see one single one of them from you that gives the OP any sort of helpful advice whatsoever so who's the Anti-DIY guy here? The FACT is that he has a problem, someone is trying to solve his problem and YOU are here bashing the solution. Here's your real problem. The OP bought the equipment and had it installed by a local water filtration company and they will more than likely service that equipment and they will have to adjust and or sort out the issues he may have with it but in the end...they can because they are there and you internet dealers (sorry ex-internet) can't give people that level of service. Nobody here is arguing that Corosex can be problematic but it should also get the job done.
  20. Gary Slusser
    Retired
    Really? ... looking back I was the second to reply (post #3), just after you replied (post #2) saying 'all's well', while I questioned the 80% Corrosex and saying the price was way high.
    Since then you said the price was a bit high and got cartoony and personal while DH filled the thread with gobs'n gobs of words but never did solidly answer the OP's questions and had no concern of the new equipment not working. That's the California PC speak I mentioned. You've also said the new stuff should work and I don't think so but, what do ya wanna bet Dh may have voted for Moonbeam?
  21. Tom Sawyer
    Nov 29, 2010
    Maine
    So here is your post, where is there ANYTHING helpful in that ? LOL
Similar Threads: Water softener
Water Softener Forum, Questions and Answers Water softener discharge question............ Mar 11, 2017
Water Softener Forum, Questions and Answers Extending length of water softener drain Mar 4, 2017
Water Softener Forum, Questions and Answers Water softener and iron filter sanity check, before I purchase Mar 4, 2017
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Feb 19, 2017
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
