Water softener pellets vs. crystals
Discussion in 'Water Softener Forum, Questions and Answers' started by kwust, Apr 25, 2012.
  1. kwust
    kwust WaterManiac
    Apr 25, 2012
    Utah
    Which works better for water softeners?
    Pellets?
    Crystals (by this I mean the rock salt)?
    My guess is pellets because it's more expensive -- but does it really work better?
    Thanks in advance for your replies.
  2. chevy427
    chevy427 Banned
    Nov 20, 2010
    USA
    Actually, rock salt and crystal salt are different with rock salt being a lower quality--RE: dirtier. I would never use rock salt unless an emergency and only enough to hold you off till you get better salt.
    It may also depend on the softener. Most standard softeners use hard, iron-laden water in the brine drum so the quality of the salt isn't as essential. But if your softener uses treated water in the brine such as with twin tank or some high quality single-tank systems, then use pellet or cube salt only.
    Are you currently using a softener or making plans?
  4. ditttohead
    Jan 9, 2012
    Ontario California
    Rock salt quality is partially a regional issue and a QC issue. Salt is very heavy and expensive to transport so rock salt in one region of the country may be dirty, while oters may be very clean. Salt is rarely transported long distances. For the most part, salt is salt. I use rock salt, but our sources are very clean here in California. I have been to parts of the country where the rock salt will leave dirt residue after only a few bags. I would avoid salt that is dirty. If you do use dirty salt, be sure to clean and sanitize your brine tank annually. Let the brine tank run almost empty of salt, then clean it, add a 5 gallons of water, fill it with salt, and regenerate the system. it might not be a bad time to sanitize the resin bed as well.
    FYI, I used to sell millions of pounds of salt a year, we only used solar rock salt. Again, our source was clean, so it was not a big deal.
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I'm not a fan of pellets but some folks have good results with them. We don't sell pellets though.
  6. Gary Slusser
    Retired
    Solar crystal is best because it doesn't have the problems or price pellets do. I would not use rock salt. Or 50 lb block salt.
Similar Threads: Water softener
Water Softener Forum, Questions and Answers Water softener discharge question............ Mar 11, 2017
Water Softener Forum, Questions and Answers Extending length of water softener drain Mar 4, 2017
Water Softener Forum, Questions and Answers Water softener and iron filter sanity check, before I purchase Mar 4, 2017
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Feb 19, 2017
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
