Hi everyone, I'm planning to install a new water softener (48k, with a Fleck 5600SXT control) and whole-house carbon filter (this one, with a Fleck 2510 control), and I have some questions about the plumbing:
1) Can I tie the drain lines from the water softener and whole-house filter (backwashing type) into the 3/4" drain pipe that is currently used for the dehumidifier and AHU condensate? I'm concerned that 3/4" might not be large enough to handle the flow rates during backwashing. Here are some pictures of the drain line run from the AHU down to the crawlspace:
2) If I can use the AHU 3/4" drain line, can you recommend a good air gap device to tie the softener and filter drain lines into it?
3) I want to bypass the water filter system to provide non-softened water to the two outdoor hose bibs and also to the kitchen sink (to the drinking water filter). Should I tee off of the main cold water line that's just above the water heater, and run separate PEX lines to these three fixtures? Or is there a better way to do it?
Here are some more pictures... The water supply goes into the wall cavity behind the water heater (which is adjacent to a coat closet) and then down into a really tight area of the crawlspace. Here's a picture of it:
Here's a picture of how the water lines tee off the main supply lines to go to the outdoor hose bibs (similar tees go to the kitchen sink). I assume this is standard:
I'm new to DIY plumbing, but I think I can handle PEX (famous last words ). What tools and fittings would you recommend? I'm leaning toward the standard copper crimp type connections, but I'm open to other options. Any other advice or tips would be greatly appreciated!
