Water service line from street...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by OldPete, Jul 12, 2007.
  1. OldPete
    OldPete DIY Senior Member
    Jan 4, 2006
    NJ
    I recently encountered a situation where a black plastic (the roll type) pipe was coming in from the street (service) -- I am trying to determine what kind of pipe it is, there are no markings that were legible. What are some options?
    It is connected to a 1">3/4" NPT -- like a 1" slip fitting (not sure if that's the right name for it) on one end and a 3/4" NPT on the other copper fitting with two hose clamps!!! (Yikes??!?).
    (I won't even tell you that the power was grounded to this mess.)
    Any ideas much appreciated.
    Thanks.
  2. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Sounds like whats called a "ford" fitting, I could be wrong...also...the power is supposed to be grounded on the water main.
  4. OldPete
    Jan 4, 2006
    NJ
    I don't know about the fitting name, but I *do* know that the power is NOT suppose to grounded on the water main when the main isn't metal!!! It is suppose to be on a rod/acorn set-up. That much I *do* know.
    Now... back to figuring out what I got. :)
  5. dubldare
    dubldare Plumber/Gasfitter
    Sep 14, 2005
    Plumber/Gasfitter
    MN/ND
    Sounds like an insert (barbed) fitting on the end of that poly.
Similar Threads: Water service
Plumbing Forum, Professional & DIY Advice Water service fittings pack joints May 3, 2014
Plumbing Forum, Professional & DIY Advice 1 1/2 water service to home aprox 1300 ft. Mar 5, 2014
Plumbing Forum, Professional & DIY Advice Need expert help, polybutylene water service? Oct 7, 2013
Plumbing Forum, Professional & DIY Advice Water service upgrade for home fire sprinkler Apr 1, 2013
Plumbing Forum, Professional & DIY Advice UPC Code question about water service sizing Sep 13, 2012
