water running noise
Discussion in 'Irrigation / Sprinkler Forum' started by kylee, Aug 13, 2007.
  1. kylee
    kylee New Member
    Aug 13, 2007
    I found this forum searching the internet for how to install an expansion tank to my water heater. A thread back in 2006 matched the problems I am having almost perfectly. I realized that the problem may lie in my spinkler system. I did not see the resolution to the posters problem so decided to try a thread myself. Today my expansion tank burst. For the past 3 months roughly i have been hearing a water running noise in my living room directly above where the water enters our house. We just installed a new spinkler system last year but only began using it this summer when we laid sod. I called a plumber to come check out the water noise i had been hearing and was told that our toilet needed the fill valve and fallper replaced, wich we did. The noise lessened some but did not go away. Like the poster last year we also have a terrible noise when the spinklers change zones. I really never thought anything of it until now. So, our sprinkler syster taps into the main water line before it enters the house and before the shut off valve and the pressure regulator valve. We do not have a pressure guage so i do not know what pressure the water comes into the house at. Today the expansion tank burst and before i replace it I wanted to know if the water running noise the loud spinklers and the broken expansion tank were all connected. Anyone's input would be really apprecitated. Hope it all made sense. Thanks.
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Water hammer could do all kinds of damage, but a pressure regulator usually blocks the worst of water hammer. What's the regulated pressure in the house? What's the unregulated pressure in the street? Maybe the sprinkler system could have it's own little expansion tank, or water hammer reducer, added just upstream of the zone valves.
  4. Kiril
    Kiril New Member
    Jun 19, 2007
    Sacramento, CA
    Ditto. If water hammer is the issue it can be corrected with one of these installed as boots suggested, upstream of the valves.
    http://www.watts.com/pro/_productsFull.asp?pid=627&ref=1
  5. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    Nebraska
  6. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    Nebraska
Similar Threads: water running
Irrigation / Sprinkler Forum No hot water when pro-installed irrigation system is running Jul 27, 2013
Irrigation / Sprinkler Forum Water Master drip system that won't stop running Jun 7, 2007
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Yard hydrant/automatic horse waterer question Sep 5, 2016
Irrigation / Sprinkler Forum Things to buy to do under ground water line? Aug 14, 2016
