Water Right Sanitizer Plus - Hit 'Next' During Regen Process
saniplus
Wisconsin
I have a Water Right Sanitizer Plus System.
Did I cause any harm by pressing 'Next' while the regenerate process was going? The screen changed from Backwash to Rinse when I did that.
Akpsdvan
Alaska
It could be the Fleck 4200 with the SE control as WaterRight used that one first then moved to the Clack.
Either way Gary is correct, all you did was shorten the back wash time , this time around.
It would depend on how much time was left when you pushed the "next" if you where only 1 or 2 minutes in ... then another cycle would be good, if you only had a couple of minutes left when you pushed it .. then no worries.
Rjh2o
Michigan
That is the Clack valve and just as Gary said it just advanced to the next cycle. No harm done.
RJ
