Water Pulsating
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by swooten, Dec 3, 2008.
  1. swooten
    swooten New Member
    Dec 3, 2008
    I have an Wellsaver LPT20 tank. air pressure is set at 28lbs two below start up. Problem is water is pulsating in the house and presure gauge is cycleing on and off as well as pressure jumping up and down....Thought i might have air in lines, so shut off water and opened all valves. When iturned water back on had steady 60 lbs pressure and good water flo NO pulse...BUT as soon as i cut one faucet off problem starts back...HELP
  2. Cass
    Cass Plumber
    Nov 12, 2005
    It sounds like your bladder tank is shot.
    turn off the pump and open a faucet to let out all water pressure from your home, then check the tank pressure by letting out all the air and see if any water comes out... If all is OK check the 1/4 " tube going up to the pressure switch and be sure it is clear lastly it may be a bad diaphragm on the bottom of the switch...
  4. Gary Slusser
    Retired
    All new tanks come with no water in them and that is how and when the air pressure setting is done, with the tank empty.
    If the pressure tank is in a basement, or below the highest fixture in the house, you should drain the pressure tank to check or adjust the air pressure because the weight of the water in the lines will cause a false pressure setting of .433 lbs per foot of water above the tank. Plus with the faucets closed, and water in the tank, the air volume will not be correct although the pressure will look correct the bladder will not be stretched correctly in operation of the system.
    Incorrect air pressure and subsequent volume is the primary cause of failure of precharged captive air tanks. Short cycling of the pump causes tank failure sooner tha nif the air pressure and volume was correct.
  5. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Possibly a bad tank?
    It sounds like a bad tank. Hopefully the pressure switch pressure line input is near the tank.
    Cycling kills pumps; tanks and pressure switches. I would suggest that if and when you replace the tank that you would also install a Cycle Stop Valve www.cyclestopvalves.com. If replacing the tank you may also want to consider Cycle Stop Valves new Pside-Kick when replacing your existing tank.
    A Cycle Stop Valve will stop cycling and give you constant pressure (like city water pressure).
Similar Threads: Water Pulsating
Pumps and Tanks Well Forum & Blog. Water is life. Water pulsating at fixtures Dec 14, 2013
Pumps and Tanks Well Forum & Blog. Water is life. After brief power failure, I have pulsating water and the well pump is cycling A LOT Jan 27, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Can/Should I install water meter in Single Family well fed system? Yesterday at 7:43 AM
Pumps and Tanks Well Forum & Blog. Water is life. Newb questions about water storage Yesterday at 6:26 AM
Pumps and Tanks Well Forum & Blog. Water is life. 4 Inch Well, Water Full of Sand, Ideas Welcome! Monday at 11:58 AM
