Jsiceloffj
I have a 3/4 in incoming line from a municipal supply with a pressure regulator set at 60 PSI. During the day, the pressure varies from 60 PSI to 100 PSI. This is measured on a gauge after the regulator. It returns to 60 PSI after a time, only to return to 100 PSI later. The regulator has a range of 25 to 75 PSI. I do not have an expansion tank. Is that a solution?
Obviously this is causing many problems with my plumbing. Any ideas?
