Water Pressure problem
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Satman858, Oct 7, 2007.
  1. Satman858
    Satman858 New Member
    Oct 7, 2007
    Yesterday I lost water pressure from my well pump. The gauge on the pump is on Zero. There is a little water coming out the facet with very little pressure, but I would think it will completly stop soon.
    Does anyone have any idea what might be the problem?
    Could it be the pressure switch attached to the pump, as I have a extra one?
    Thanks in advance for your replies.
  2. Gary Slusser
    Retired
    You didn't describe the problem or your system very well....
    I assume you have a jet pump (above ground) since you osay the switch is on the pump....
    Is there power to the pump?
    Are the points in the pressure switch closed?
    Is the motor running or humming?
    If yes yes no, then there is something wrong with the motor.
  4. Satman858
    Oct 7, 2007
    Is there power to the pump? Yes
    Are the points in the pressure switch closed? Do not know how to tell that. :confused:
    Is the motor running or humming? humming
  5. Satman858
    Oct 7, 2007
    Is there anyone else that might be able to help me know what the problem is?
    Since the pump is making a hummimg noise I would think it is not the pressure switch.
  6. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Your correct, if it's humming, it's getting power. There is a start switch, a centrifugal switch and a start capacitor in most motors. There could be a bug in the switch (between the points), the start cap could be bad and the centrifugal switch could be stuck in the down position.
    Your motor could be bad too. If you don't know how to trouble shoot these things, a pump tech would be your best bet. If you can't find a pump tech, call a well driller.
    bob...
Similar Threads: Water Pressure
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Feb 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Low water pressure on well system Jan 17, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Newbie help with water pressure issues, thinking of a CSV Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure trouble shooting Nov 12, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Complete redo of water plant - replace pressure tank with CSV Oct 17, 2016
