water pressure in the shower
Discussion in 'Shower & Bathtub Forum & Blog' started by mudd, Jun 21, 2006.
  1. mudd
    mudd New Member
    Jun 21, 2006
    we have good water pressure everywhere in the house but the master shower. is there something i could do to help this problem?
    do they make a special shower head that helps this?
  2. jadnashua
    check the screen behind the shower head and at the shower valve.
    Check the flow into a bucket. It should be around 2.5 gallons/minute from the showerhead. If you get that, it is doing its federally mandated job. Not all showerheads are created equal...some do a much better job with the mandated maximum flow than others.
  4. mudd
    mudd New Member
    Jun 21, 2006
    i see the screen behind the shower head but
    where is the shower valve you are refering to?
    is it 2.5 gal/min with the shower head on or off?
  5. jadnashua
    The restrictor is in the showerhead...so, to see if you are getting the volume mandated, leave it on.
    The other place there may be screens is in the valve assembly that controls the shower.
Similar Threads: water pressure
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Occasional Low Water Pressure Jan 19, 2016
Shower & Bathtub Forum & Blog Concern of water pressure on well for dual shower head setup Dec 5, 2015
Shower & Bathtub Forum & Blog Tub Water Pressure Help... Sep 28, 2015
Shower & Bathtub Forum & Blog Drop in water pressure when flushing toilet Jul 18, 2015
