My water pressure has started to drop significantly periodically for very short periods of time. Depending on the flow rate of the water, every 2 minutes or so the water pressure will drop off significantly for a 1 or 2 seconds, then recover completely, and the cycle continues consistently. The cycle timing seems to be roughly the same as my pump cycling On/Off (it does not seem to be short-cycling, and the pressure tank seems to be ok), and the recovery time seems to be too fast for a thermal shutdown issue (the water never actually stops flowing, either). Has anyone experienced this or know the cause?
