Water pouring from tub spout during shower
Discussion in 'Shower & Bathtub Forum & Blog' started by hugscot, Mar 9, 2007.
  1. hugscot
    hugscot New Member
    Mar 20, 2005
    Hi,
    I recently replaced the hot, cold, and diverter valves on my tub with a new replacement kit from ACE Hardware (new valves, washers, seats, covers,e tc) due to corrosion, leaking and water pouring from tub spout during a shower. However, when the shower is on excessive water still pours from the tub spout so the new valve did not fix this problem. What else can I do to fix this? Would a tub spout with a pull diverter fix this maybe?
    Thanks,
    Scott
  2. jimbo
    jimbo Plumber
    You have somehow not installed the diverter stem correctly. Possibly the seat is bad inside the body, or possibly the back-seat washer on the stem broke while putting it in. Anyway, take the diverter apart again and you will see what's up. By the way, when inserting and removing stems, make sure they are neither fully open or fully closed....just in the middle of the range.
  4. hugscot
    hugscot New Member
    Mar 20, 2005
    Something I noticed too when I was changing the diverter before was that when I looked to check for the seat there was just a recessed hole in the back of the valve housing, which puzzled me. :confused: The valves did not appear to have ever been pulled out before I changed them. Is that normal or could that maybe be the source of the problem? I will pull it out again and check it out.
Similar Threads: Water pouring
Shower & Bathtub Forum & Blog Cold, hot water lines to new bathroom Feb 15, 2017
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Faucet wall tubes and wall tube escutcheon is not water tight Feb 9, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
