Water pipe movement in attic
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by strainsa, Sep 2, 2004.
  1. strainsa
    strainsa New Member
    I recently moved into a 5 year old house. It has a water heater in the garage servicing the kitchen and 2 bathrooms. Another water heater is in the attic servicing
    the other 2 bathrooms (I would guess for quick hot water in the showers). The pipes coming from the water heater in the
    attic sometimes have a minor rattle noise. The pipes travel 5 feet down the side of the heater, 4 feet horizontally in the
    attic and 10 feet down between the walls into the concrete foundation. I have noticed that there are no clamps securing
    the piping in the attic. I cant tell in the walls. Is this normal not to secure the pipes? Is it to allow them freedom
    to move for expansion (hot water flowing in clod pipe)? Can I put some copper clamps on to secure the pipe and keep it
    from rattling? Looking for any ideas or options from you all. thanks..
  2. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    The piping could be rattling for other reasons besides not being properly secured.
    Start with using copper straps to secure the piping, see if that helps.
    Piping insulation on HW pipes can save energy.
  4. jimbo
    jimbo Plumber
    Good call by e-plumber on insulating the hot piping wherever you can access it. You will be impressed how much difference this makes.
    Be sure to use only plastic or copper strapping. Galvanized straps in contact with the copper cause problems.
    If you have a "groaning" noise, it can be cause where the copper passes through a joist or stud, and expansion causes rubbbing on the wood. The holes should have been larger, or had plastic bushings installed. Probably too late to fix that.
    A "banging" noise might just be fixed by securing the pipes as much as possible, but it is worthwhile to check that your household water pressure is not too high.
  5. strainsa
    strainsa New Member
    followup
    All the exposed hot water piping is insulated with a rubber/foam tubing. I was curious what "The piping could be rattling for other reasons besides not being properly secured" might mean. Could you elaborate on this?
  6. e-plumber
    Sep 1, 2004
    New York
    followup
    Piping will rattle, shake or bang if an internal faucet part or similar is loose, there is excessive water velocity through undersized water lines and/or high water pressure.
    The vibration/hammer that is created can reverberate through the water lines and in some cases will cause a weak or old connection to burst.
  7. dudetoilet
    dudetoilet New Member
    Sep 25, 2015
    Toronto, Ontario
    is it possible that a toilet brush head could be stuck in the water pipe
  8. Terry
    Aug 17, 2004
    Nope! :)
Similar Threads: Water pipe
Plumbing Forum, Professional & DIY Advice Bathtub drain not connected to drain pipe; bathwater draining into foundation Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Water on outside of PVC vent pipe in basement Feb 3, 2017
Plumbing Forum, Professional & DIY Advice How to drain water out of pipe Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Water pipe sizing Jan 8, 2017
Plumbing Forum, Professional & DIY Advice Banging noise from copper hot water pipe (not water hammer) Dec 19, 2016
