Water Main Shut off and Electric Hot Water Heater
Discussion in 'Water Heater Forum, Tanks' started by mrmichaeljmoore, Jan 6, 2010.
  1. mrmichaeljmoore
    mrmichaeljmoore Member
    Jan 17, 2007
    I have a question regarding turning off the main water supply to the house but leaving the hot water heater on. The water heater is a Whirpool ELECTRIC water heater. I think it is 40 gallon.
    Here's the backstory: I came home last night to find that the supply line to my basment utility sink had worked its way loose, dumping a few inches of water onto my basement floor.
    Needless to say, I am now a bit paranoid about leaving the house and coming home to find a pool in my basement.
    So, I was thinking that when I leave for work in the morning, or go away for the weekend I will turn off the well pump switch and close the ball valve at the bottom of the well retention tank....thereby if I do get a leak, only what is in the lines will come out...
    But, I remember reading somewhere that turning off the water supply, but leaving the hot water heater on could cause a problem. Something about evaporation in the water heater tank??
    So, here are my questions:
    1. If I decide that everytime I leave the house, I will turn off the main water supply to the house, should I turn off the breaker to the water heater?
    2. How long can the tank sit powered on, but with the water supply closed?
    3. Would I need to turn it off daily when I leave for work or only when I go away for a few days?
    Thanks.
    mm
Similar Threads: Water Main
Water Heater Forum, Tanks Old water heater and preventative maint. Dec 27, 2016
Water Heater Forum, Tanks New Ruud gas water heater won't maintain temp Mar 14, 2013
Water Heater Forum, Tanks Whirlpool Flame Lock Heater Often Fails to Maintain Hot Water ("False" Status Light) Jul 6, 2012
Water Heater Forum, Tanks Low Hot water amount since main valve replacement. Volume seems fine Jan 18, 2012
Water Heater Forum, Tanks Water heater maintenance Oct 23, 2010
