Water line for outdoor kitchen
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Dprofets, Mar 24, 2014.
  1. Dprofets
    Dprofets New Member
    Mar 24, 2014
    Ca
    So I got this crazy notion of ripping out a small deck that was in the back yard when we moved in and replacing it with an outdoor kitchen. I am planning on running a cold water line to a sink. It will be buried underground under concrete. I have a line to tap off of about 10' away. What would be the best pipe to use and how do I find out how deep to go? I had a plumber out for the gas line I need to run and he quoted me pretty high for the gas, water, and drain to be run. I feel I can handle the electrical, water and drain to save some $$$.
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    The type of pipe depends on the code in your area and depth depends on where you are in California - Calexico will be different than Incline Village. Cold water will probably be the easy part. Gas under a slab and a properly installed drain are more complex.
  4. Dprofets
    Dprofets New Member
    Mar 24, 2014
    Ca
    I am in Southern California between San Diego and la. Temp is very mild here. Gas line is definitely going to be done by a professional. Thanks for the reply. How can I find the code in my area?
Similar Threads: Water line
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Reverse osmosis and cooper water line Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Basement water lines Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Cold Water Line to Kitchen not Working Jan 9, 2017
Plumbing Forum, Professional & DIY Advice Water supply line to short for new toilet Jan 2, 2017
