water level drop
Discussion in 'Shower & Bathtub Forum & Blog' started by johnfrwhipple, Dec 25, 2011.
  1. eurob
    eurob master tile and stone installer
    Feb 16, 2013
    Montreal
    :) Thanks , William. :)
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Vegas how is your shower working?
    Did you do the testing with the grate off?
    JW - "When it's perfect. It's Good Enough."
    www.No-Curb.com - my blog site on Barrier Free, No Curb, No Dam and Hobless Showers
    (604) 506-6792 jfrwhipple@gmail.com
  3. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  4. Jean-Claude JC Lussier
    Jean-Claude JC Lussier New Member
    Apr 17, 2014
    Manitoba
  5. Jean-Claude JC Lussier
    Apr 17, 2014
    Manitoba
    It is the schluter shower kit surrounded by a custom bench on 2 sides. The floor is using the schluter floor pan.
  6. Jean-Claude JC Lussier
    Apr 17, 2014
    Manitoba
    The original water line was in in fact just 1/4" below the top of the curb. The water was about 5" deep.
  7. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    I would run a bead of Kerdi Fix along the top of the curb. Or top the curb with a little Ardex 8+9. Either would act like a capillary break for the flood test.
    If your using a tile profile for the curb top you could set that with Kerdi fix and that would be an awesome capillary break. If you are setting 3/8" tile I recommend a 1/2" or 5/8" Stainless steel profile. This will allow some setting material below and account for the grading of the curb.
  8. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Jean Claude - I hope my tips help you out. You do realize that Schluter has no specification for a capillary break. They require flood testing but offer up no insight for this capillary leaking.
    I don't think Noble has a spec either.
    Nor does Laticrete.
    Yet all will suffer from the same fate unless you tackle the capillary beast. Thanks for liking my post. I'm sure Jim will respond and tell you my idea is crazy. Not allowed. That your warranty will be screwed or to double check on the John Bridge forum.
    But those ya who's don't know either.
    I had the pictures up before but deleted my Kerdi info....
  9. jadnashua
    Capillary action requires a pond of water. Once you put your tile on top and grout it, the amount of liquid water that gets underneath the tile is miniscule and over a membrane, if your slope is proper, that that does not flow down the drain on top of the tiled surface and soaks in will evaporate before it gets a chance to wick anywhere it could cause damage. But, if your slopes are incorrect, you could have an issue.
Similar Threads: water level
Shower & Bathtub Forum & Blog 2nd floor shower drain water level? Mar 28, 2010
Shower & Bathtub Forum & Blog Water comes out from shower diverter spout Monday at 12:34 PM
Shower & Bathtub Forum & Blog New water heater issue?? Apr 15, 2016
Shower & Bathtub Forum & Blog Low water flow to a shower head can be caused by a low-flow rough-in valve/cartridge Apr 9, 2016
Shower & Bathtub Forum & Blog No water from Kohler Rite-Temp Valve Mar 13, 2016
