Water leaks showing on living room ceiling
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ronsaxton, Apr 30, 2009.
  1. ronsaxton
    ronsaxton New Member
    Apr 30, 2009
    i have water spot showing about 6-9 inches in diameter on livingroom ceiling and the Master Bath is over this area. this home was built in 2006 , i have nevr done plumbing work and i want to cut out the ceiling peice and attempt to stop this leak from happening please give me any and all advice , thanks
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I like to see if the leak can be found before cutting holes.
    Careful measuring and finding the corresponding location in the upstairs bathroom may help.
    Post back once you have done that.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    When you make your report, be sure to note what kind of pipes are used in the attic. Keep in mind that the water could be coming from a vent pipe and water will follow a rafter for a considerable distance before dripping off so look for stains on them.
  5. hj
    The attic may be immaterial because they stated that it was the ceiling beneath the second floor bathroom. The only advice we can give you, based on the information you submitted, is to open the ceiling at the leak point and then search for the source of the water. Where it is leaking, however, may not be right below where the leak is.
  6. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    For the drywall repair, cut the patch a little oversize, trace outline on ceiling, and cut ceiling opening to match patch. Use strips of 3/4 plywood parallel to joists, drywall screwed to the ceiling and then to patch, if the ends are not landing on joists.
  7. wraujr
    wraujr Member
    Sep 24, 2007
    Start by inspecting the shower and tub
    Do you have a shower, check for missing grout or caulk inside shower.
    If a tub, check for loose overflow or drain inside tub.
    Check for seal around fixtures, especially shower.
    If shower stall, does it have tiled seating area, these horizontal surfaces are notorious for leaking.
Similar Threads: Water leaks
Plumbing Forum, Professional & DIY Advice Only soapy water leaks? Feb 26, 2015
Plumbing Forum, Professional & DIY Advice Newbie Installing Water Filter -- Small Leaks Driving Me Crazy! Jul 9, 2013
Plumbing Forum, Professional & DIY Advice repipe hous and now hot water heater leaks Nov 15, 2011
Plumbing Forum, Professional & DIY Advice Leaks only when hot water tank is on - fatigued joint? Jun 9, 2011
Plumbing Forum, Professional & DIY Advice Dryer Vent pipe leaks water on the floor. Oct 14, 2010
