water leaks back into well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mike3232, Jan 29, 2007.
  1. mike3232
    mike3232 New Member
    Jan 29, 2007
    I have a Myers jet pump on my well. Pump will run till gauge gets to 55 or so then stops. Pressure will slowly drop for about 8 min til it gets down to 35 and pump kicks on and runs back up. This happens when their is no leaks or water use in the house. A well guy came out and said I probably had a bad valve in the well allowing water to drain back into well. I live in MN so ground is frozen and he suggested I put up with it until thaw and then I could have it repaired if I wanted. Is there any other options either temporary or permanent? The pump running every 8 min may drive me nuts before spring!!
    Thanks
  2. mike3232
    mike3232 New Member
    Jan 29, 2007
    I forgot to mention there is no well pipe or stump above ground outside. The jet pump is in the basement and nothing is above ground outside
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    If it is a shallow well jet pump, (one pipe going to well) you can install a check valve at the pump. I don't like doing that for sanitary reasons, but it will remedy your problem. I would like to add temporarilly since it is really not a good thing to do.
    bob...
  5. mike3232
    mike3232 New Member
    Jan 29, 2007
    Thanks Bob
    My pump has two pipes coming in from well. In this case am I out of luck until
    spring or are there any other options???
  6. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Keep lots of air in the tank to get the maximum drawdown. If not, your motor is going to have a shortened life.
    Also if the power goes out, you may have a real time of it trying to reprime the pump without the aid of a neighbors hose to backpressure the system.
    bob...
Similar Threads: water leaks
Pumps and Tanks Well Forum & Blog. Water is life. Remote cabin water problem Saturday at 12:53 PM
Pumps and Tanks Well Forum & Blog. Water is life. Water Not Flowing Into House, Is It The Pump? Friday at 6:21 PM
Pumps and Tanks Well Forum & Blog. Water is life. Can/Should I install water meter in Single Family well fed system? Feb 21, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Newb questions about water storage Feb 21, 2017
Pumps and Tanks Well Forum & Blog. Water is life. 4 Inch Well, Water Full of Sand, Ideas Welcome! Feb 20, 2017
