water leaking out of tub??
Discussion in 'Shower & Bathtub Forum & Blog' started by GabeS, Dec 6, 2009.
  1. GabeS
    GabeS Remodel Contractor
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Hi,
    I have a perfectly level tub, however when someone takes a shower, the water drips down the front wall and when it reaches the tub of the tub, instead of flowing into the tub, it travels along the wall and drips outside the side of the tub. I was thinking of putting a line of silicone where the water leaks out and try to redirect the water back inside the tub. Not sure if it will work. Any other ideas or solutions would be appreciated.
    Gabe
  2. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Tell me that I have not just stumped the plumbing world with this question.
  4. Terry
    Aug 17, 2004
    They make triangles that fit in the corners that you can caulk in.
  5. hj
    diverters
    They are referred to as "water wings" and fit at the front corners of the tub to intercept and divert the water into the tub.
  6. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Thanks for the reply. Do you know where I can get them? I googled water wings, and a bunch of swim aids for kids came up.
  7. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Pintchik, on Flatbush & Bergen, used to have them. Not sure if they still do. That little hardware store on 5th, across from the Key Foods & next door to the bike shop? They'll either have em, or know who does.
    I suppose I should ask which part of Brooklyn you're in, none of this might be close to you... I know I asked you before, ages ago, but I don't remember.
    Be warned, those triangle generally aren't the prettiest of solutions. They're plastic, they're white, they caulk into place.
  8. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    HD carried them for a while. I suspect they still do as well as lowes
  9. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    I'm in Greenwood. That's very close to me. I will get them when I have a chance. I know it won't be pretty, but I don't think I have a choice. It's leaking out and ruining the bottom of the vanity which is made of particle board.
  10. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    I still can't figure out how to quote only a portion of someone's post.
  11. frenchie
    Dec 30, 2006
    Caretaker
    When you erase the bits of the quote you don't need, make sure not to erase the stuff that's in square brackets:
    "QUOTE=so&so;1234560", at the beginning of the quote, and
    "/QUOTE" at the end
    ... and don't delete the brackets, themselves, either.
    Stuff inside square brackets, is instructions to the software about how to format the text. More info/explanation, here:
    http://www.terrylove.com/forums/misc.php?do=bbcode
    scroll down to "usage" and it'll all start to make sense.
Similar Threads: water leaking
Shower & Bathtub Forum & Blog Water leaking from back of dome nut (Delta single tub faucet) Apr 19, 2015
Shower & Bathtub Forum & Blog Water leaking into shower at bottom grout line of tiled wall Apr 9, 2015
Shower & Bathtub Forum & Blog Water Leaking from Tub Corner Sep 15, 2013
Shower & Bathtub Forum & Blog Moen shower/tub valve leaking from stem when water is on Mar 16, 2013
Shower & Bathtub Forum & Blog Water leaking into the pan from the weep holes Jul 29, 2012
