Water leaking on bottom of faucet when turned on
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by SadPanda86, Feb 17, 2013.
  1. SadPanda86
    SadPanda86 New Member
    Feb 17, 2013
    New York
    Hi, my mom recently bought a condo and I am trying to learn as I go along. Recently the bottom of my faucet starting leaking. It only happens when I turn the cold water on. Do anyone know what is causing this?
    The red arrow is where the leak is coming over
  2. hj
    there are at least 3 possibilities, but we would have to be there to sort them out, or see it was something else entirely. So are doctors and dentists, but if you needed one, you would go to them.
  4. SadPanda86
    Feb 17, 2013
    New York
    What are the 3 possibilities?
  5. Hackneyplumbing
    Hackneyplumbing Homeowner
    Jul 30, 2012
    Alabama
    Remove the cold handle of the faucet. Now put the handle back on and turn the cold water on. While the cold water is running into the lavatory lift the handle off of the stem and inspect for leaks.
    If you find leaks then repair them.
  6. SadPanda86
    Feb 17, 2013
    New York
    So I replaced the faucet stem and seat but the problem persist. Does this mean that I need to replace the whole faucet?
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The aerator may be leaking past the threads and back into the faucet body.
    If you keep buying all of the component parts, you will have exceeded the value of the faucet.
    edited to add- I see now that it only happens on the cold side. Aerator would leak regardless of hot or cold.
  8. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Don't turn cold side on and it will not leak !
  9. SadPanda86
    Feb 17, 2013
    New York
    sorry for the delay with update, so I have decided to get a new faucet. Do I need to get new water supply line or get I just switch the faucet?
  10. jimbo
    jimbo Plumber
    The connection at your faucet looks like standard 1/2" IPS..... I say standard because it USED to be. Today, you will still find some faucets with that inlet, but MANY faucets have factory-attached flex lines, which are usually 3/8 on the end to the stop valve, in which case you will need an adapter.
Similar Threads: Water leaking
Plumbing Forum, Professional & DIY Advice water leaking shower room condominium Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Basement leaking - want advice on Waterguard or similar interior drainage systems Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Does homeowner insurance usually cover water leaking fix(e.g. repipe or reroute)? Nov 14, 2016
Plumbing Forum, Professional & DIY Advice Water leaking from the bathtub near the faucet Jul 27, 2016
Plumbing Forum, Professional & DIY Advice Water Leaking Out Of Moen Tub Faucet Handle Jul 26, 2016
